Edit:
Having cleaned and disassembled the original carburetor that was provided with the tractor, the following question about where to drill a hole does not make much sense. The Amazon reviewer did not adequately describe what he did. As JMOR pointer out, the only place where there seems to be a hole that might be in the wrong place appears to be the tiny vent holes in the side of the main nozzle.
End of edit.
My daughter bought a 2N with a brand new cheap carb that will cause the engine to stall when pointed uphill. I thought that it might be the oft mentioned sticky float, but could not see how that would cause this problem. I have seen a number of online forum questions about this. None of them ever got back to say whether any of the suggested fixes actually helped.
I read through a bunch of Amazon negative reviews about one of these carbs that mentioned the uphill problem. Finally, one of them said "i had to drill another hole lower in the bowl to let gas into the main jet when going up a hill. it would run great on the level before..." This seems to make sense to me. At least it would if I knew what to look for. I.e. where is this hole?
The engine starts immediately on the level, but not at all when pointed up a 5 incline. I have one of those Plastic mechanical inclinometers.
It is hard to accelerate in 3rd up even a shallow slope, which would cause the gas to slosh back in the carb. It also tends to surge on the level accelerating in 3rd with the Sherman in high range. It will run, but you can't start moving uphill at 5 and will die in a short distance at 10.
So is there a hole in the float bowl? Where is it? Where should the new hole be drilled? How big? How deep? Will I screw it up? (OK, yes to that one, but it's broke anyway).
If the hole needs to move less than ~1 hole diameter, do you plug it first? Would enlarging the hole for a short distance (assuming it slopes down) lower the entrance enough to do the trick?
This post was edited by Dave G9N on 07/17/2023 at 04:26 pm.
End of edit.
