littlefarmer
I've been hearing a lot about the newer AGM (acid glass mat) batteries. That's where they don't have "flooded" electrolyte like conventional batteries. Because all the acid is in a glass mat "sponge" between the plates. This has some advantages; such as faster charging, no acid leaks, no corrosion and last twice as long (or more). But most important (for farm machinery) they are much tougher in vibration and heat.
However a downside I've read (besides being higher priced) is that they are very sensitive to getting too much charge voltage. That anything over about 14 volts can damage them.
I have a Farmall H and an M, and also a IH 1420 combine. These are working machines that I farm with. And from what I've read about the AGM batteries, there would be definite advantages to having them on these machines. But I am wondering about the "sensitive to charging voltage" thing. My H and M have alternator conversions. I am wondering if my tractors and my 1420 combine charging systems can work with these AGM batteries? Or do you need a modern charging system that won't go over the 14 volt limit? Any advice appreciated!
