Agri Power 8000 tractor
jesfarmer
I have a Agri Power 8000 tractor and the hydraulic system has lost pressure. I have replaced the hydraulic pump and that did not correct the problem. Anyone know how to check the system or suggestions on what can be the problem.
No history with that Fiat. But check the pump drive to be sure it is turning. Check the pressure relief valve or system to assure
it is not stuck open to the sump. If there are internal passages or metal tubes, they can fail and dump pressure. O rings on pump
intake or internal fittings can fail often. Use a pressure test port to assess system pressure. Diagnose befor replacing any more
parts. Access a good hydraulic diagram, and repair manual. Jim
