"Ain't running right"
Lynerd
Location
NE OK
A friend of mine from SE Kansas got ahold of me and said his B that he pulled wasn't running right. Put a cam in 2 years ago and new rings. He told me had to rev it up to have any power and governor wasn't responsive. He thought the cam wasn't in time and governor had problems. I said to bring it down and a coupla hundred $ to feed my crew and we would look at it. Checked cam timing and it was 15 degrees retarded. Had slots in cam so rotated the cam forward and got it to 108 degrees ATDC. Was 125 degrees ATDC. I advanced 2 degrees from what spec said. Took governor out and it looked good. Had a MSD box with LP distributor and points in it. Got it to fire right after TDC. Cranked on it and would pop coupla times. Left choke on and still not start. Tried different carburetor and still nothing. Poured some gas in squirt can and shot some gas into carb and ran few seconds. Checked compression and was good. Didn't know what was the matter. Took carb off and looked into the intake and this is what I found. Time for a JBWELD repair. Lynn
Boy I don’t know. I’ve put jb weld on a block or 2 and even fuel system components to get by but a complete new manifold is less than the ignition box he has on it even if it’s the 300 dollar manifold. I understand money is money but they aren’t that robust to start with if I saw any issues at all bye bye try the next manifold and see.
Some have even welded their own
There’s a casting number on top of them to make sure you get the right one and while you are at it studs and gaskets hopefully he has the 185 dollar one
I'm with Fixingfarmer, once hot exhaust hits it, it's gone. Replace the manifold. Tried JB on a chevy intake, where the crossover tube is to keep the intake hot under carb. Less than 20 minutes it was gone.
