Air blow off
What do you guys use for a blow off. I don t want a attachment that only puts out 20lbs pressure. I build car engines and I could really use a good tool
now i heard of guys, none that i know personally of course, that will take a male and female milton type coupler plugs and screw them together. when
the gizmo is plugged in to the coupler, massive volumes of air come out. thats what i heard anyway.
Thanks id like to thank you . I ll just get the torch out and braze the two together. Or I could put a valve in the center and make her look store bought.
Most blow guns can be made FULL flow : ) these two are older than the hills I use them mostly when going engine work... Remove the original tip and find a brass fitting that will screw in then make up copper extensions for it...
now here is a nudder option. i heard lotta guys take the milton air chuck plug, screw it in a pipe coupling and then install a hose barb on the other end.
yup, that what i hear a lotta guys do. yup lotta guys. not me of course. they look kind a like this. cheap too
Like Hobo sez - brake line fittings will screw into those type of blow guns, and you can bend the brake line to get into a tough spot. We've all got scraps of brake line.
This is what I use for blowing out my radiator from the back. I can get lots of crud out with it. The barbed brass for tubing just screws in like the original nozzle.
A fitting like that is handy for other reasons too. I happen to know someone who uses one to fill a portable air tank equipped with a female coupling. ;-)
