Jpvano28
- Location
- Greeneville TN
Hey all, I'm back ..
How do you remove the air cleaner filtering element on a 550? I don't want to break or bend anything, I can't figure out how to get it out. Thanks ... Joey
Yes, in extreme cases, ie.... Purchased a tractor new to us, after taking the oil cup off, unbolt that assembly and clean with solvent and then final gas clean, let dry for a spell, then re-assemble.Thank you .. appreciate the advice.. I’m new to this tractor thing ..![]()
Thank you .. I managed to clean up the mesh with diesel fuel and an air compressor.. it turned out to work pretty good..I took apart the air cleaner for my 1963 770 after I learned that the wire mesh was on the inside of the canister.
I used a 1/8 " drill bit to drill out the crimps and removed the bottom and twisted and pulled the wire mesh out.
The only precaution is to make sure you only drill through the 2 flanges, otherwise you damage the bottom screen.
Which was easy to make a new one with metal screen material.
When done used pop rivets to hold the assembly together.
Hope this helps.
