Air cleaner super A
dave01
Can the steel mesh inside the air cleaner housing be removed for cleaning on a 1951 super A ?
As always- Thank you thank you !
later,dave
Not without major intense effort. Were it mine, I would put Kero/diesel in the cup, seal every hole as needed, including the cup to body joint, and hose clamp it to the wheel of a tractor and drive for a half hour. Jim
I have taken them apart, it is a real pain.
Grind the spot welds off on the retainer, pull retainer without messing it up, then pull the mesh out.
When ever I want to clean one up I take a 5 gal bucket and put the air cleaner in it then fill it with gas and let it sock a few days. I do try to agitate it some to help free up the junk so it falls out and down to the bottom of the bucket
