Air Compressor Drain
super99
The post below talked about draining your air compressor.
When my old Sears Oil less died a few years ago, I told Alta
that I was going to Menards to buy a new compressor, so she
went with me. I was trying to decide how much to spend when
she said, which one do you want. I pointed to the 80 gallon
upright and said that is what I want but it?s too expensive , so
I?m looking at a smaller one.
She asked me if I planned to live long enough to wear out
another one before I got the one I really wanted. I said
probably not.
So I got the one I wanted, but the drain was under the tank in
the middle and I had to lay down on the floor to see it and
reach it to drain it. I took the drain plug out and put a piece of
pipe and a shut off valve where I can reach it easy. I tried to
get a picture when draining it out, but there wasn?t much in it
because I drain it every time I use it. Chris
super99, my wife chastises me occasionally because, I am a cheapskate. I have spent hours trying to repair something, then had to go buy new anyway. So I am transitioning to a better judgement system on repair or replace. Often times now her question will be, "do you need it, better go buy it". Definitely makes life easier not having to justify every cent I spend on my tractors or tools. Life is good!! I also need to plumb my air compressor to make the drain more accessible. gobble
Plumb it up like his and then add a little plastic tubing or copper line on the end of the valve. Drill a little hole in the back wall and you can just squirt away every now and then. If the humidity is crazy high leave that drain valve just bairly cracked the whole day or until you are finished. Let's all of the water out with the loss of not that much air. Least that is what I do.
I have the same type of drain setup with a ball valve, but I put a male air coupler on it & attach my air hose to it so I can run it out side of my shop when I drain it
I removed the drain valve and replaced it with the cable type used in semi truck air tanks. I mounted the cable so I barely have to bend over. The easier it is to get to the better chance it will get used.
It's either "Great minds think alike" or "Small minds seldom differ". I have an 80 gal unit that I did exactly the same thing to. Cheers.
I have brought expensive auto drains they all failed in time... I am back to where you are at... I use my foot to blip it every time I turn it on are off are when I walk by it : )...
Cordless tools have about eliminated my use of compressed air...
Mine is plumbed just like that,I turn off the air & power then dump the air for a little bit.
My compressor is sitting in the middle of my shop with no real way to get the drain to an outside wall. My solution was drilling a hole through the cement slab and running a plastic tube from the valve into the hole. Now all that goopy water goes under the slab instead of out on the shop floor.
I did something similar. I added a three foot vertical makeshift tee topped length of pvc pipe atop the valve handle so I can drain the tank easily anytime I walk by without bending over. I seldom get more than a puff of mist. TDF
My wife is always coming home from shopping and telling me what great buys she found. It is usually clothes or the supplies that she gets at the drug store. A while back there was a major purchase that I had been shopping around for for a week or two, and I finally pulled the trigger. She came home and told me about what she had saved, then I told her that I had saved $1,200. The smile dropped from her face and she yelled "What did you buy?"
That's the sensible thing to do since being easy to reach, and in plain sight makes it easier for you to remember to drain it....and actually do it. I do it to mine. Flip side is I never had a tank rust out and one of my tanks (60 gallon upright) is over 30 years old...Campbell Hausfeld (spelling?).
did same thing other than I installed 50 ft hose and use it a lot times to air stuff or whatever it actually drains 2 c80 gal tanks teed together
Good evening: I have a Sears/Craftsman (actually Campbell-Hausfeld) I bought new over 35 years ago. I need to drain tank more that I do. This is about a 2 hp unit, fed from 120 volt circuit in my garage. BTW (OT), last year some field mice got into the air filter on top of the cylinder head, and stored some acorns on top of the "flutter" valves. It quit pumping. Hard to find parts locally but I got them and fixed it.
Dennis M. in W. Tenn.
