Thanks in advance for any help or advice.....
I was given what appears to be a "homemade" air compressor. Homemade in the sense it appears someone took a legitimate tank, an electric motor (.5 hp if I am seeing the tag correctly), various fittings, pressure switch to turn it on and off, a gauge, and what appears to be a compressor from some type of AC unit and put together an air compressor. It worked just fine for awhile (and it appears to be an older piece of equipment, so I assume it worked for quite awhile prior to me), and then it just quit pressurizing the tank beyond about 15-20 psi.
There aren't/weren't any leaks, and I don't question the safety of the tank. The tank hasn't been welded on or anything. It looks like a "factory" tank of some kind, probably for an air compressor. It has a valve on the bottom for draining water. With the stand, the tank is probably about 5 ft tall. The compressor and motor sit on top. The electric motor is still good.
It seems a shame to just scrap the whole thing. If I can replace the pump, I may keep it or give it to my brother. He doesn't run a bunch of air tools or anything (nor do I), so this is mostly for keeping the car tires up and blowing out dirt and dust, etc.
Does anyone have any suggestions/sources for a new air compressor pump (I am assuming the old compressor is the problem) and a guess as to what size I can run with the motor I have? I'm not looking to build an industrial strength air compressor or anything. I just want a working compressor so I don't have to throw this away.
Thanks again....
Thanks again....
