Air Compressor???
SJ
I have a craftsman oilless compressor,that would blow the breaker turning it on when really cold out.Dont really worry about it,as it will always work when it warms up.Well I really need it now.Im trying to heat up motor and piston area with a blow dryer with no luck.He11 I cant even get the cover off,cover screws just keep turning and turning with no results.I reached in with a screwdriver and motor fan and piston move freely.My question is.Is there a specific component that I should be directing the heat to so it will free up?
Stan
It sounds like you need to upgrade the breaker and probably the associated wiring to make them adequate to start the motor.
For now, why not just drag the compressor in the house for a few hours to thoroughly warm it up?
Its on a 20amp breaker with 12-2 wire
Model no.919.165230
max 130psi
120vo/60hz/1ph/15amp
I guess I could bring it in the house,that would be a real pain though,maybey I dont really need it that bad,,LOL
Stan
Code book says a 30amp breaker to supply a motor with full load ratings of 11-`15amps with short circuit protection.16-19 amp motors require a 40amp breaker.
The motor's thermal protection provides overload protection.
There is a common misconception that breakers and fuses provide overload protection....nope folks. They are only designed to interrupt current during short circuits.
Piston area. I've got one but not airless, when it was new a bunch of years ago, the tight piston would pop the breaker in cold weather. As the thing got used more and the piston wore in some, it doesn't happen anymore, in no kind of weather. Your's being airless might have a different piston configuration so....either it's new and tight or older and used and still tight.
A heat lamp over it will fix the problem in a few minutes. Even a 100w light bulb next to it will work. The 100W bulb can be left on all the time.At our rate it only cost $0.10 a day.
My son in law"s compressor does the same thing, throws a breaker before it will run in cold weather.
We needed it to blow out a sprinkler system so I had him reset the breaker, then turn the compressor off, open the tank so no pressure could build until the motor was properly running, and then start it up.
Worked like a charm. They just don"t want to start under compression. Keep it from building pressure until the compressor warms enough to keep going and you are all set.
