(quoted from post at 12:42:22 09/30/09)
(quoted from post at 18:54:49 09/29/09)
(quoted from post at 14:08:23 09/27/09) I bought a 60-gal Campbell Hausfeld 12 years ago and it's been very dependable. The only thing I'd caution about is who/where to buy it and be aware of your actual output needs. (RE: the comments above about capacity while sandblasting, etc.)
This unit puts out all I need for my purposes (about 10 cu ft @90 psi). I bought it at WalMart when they were discontinuing sales of this large compressors, and paid $250. I"ve seen them for sale below $400 very recently at various places. It's a single stage cast iron splash lubricated.
The use of improper oil in the compressor (ANY brand) will cause carbon to foul up the unloading valve such as mentioned above. Use either non-det motor oil, dedicated compressor oil, or dedicated synthetic compressor oil sold by CH.
PS- Whatever brand/model you buy, if you get an upright ...be CERTAIN to tie it to the wall and/or bolt it to the floor. They are all top-heavy and you do NOT want it pulled or knocked over. You'll probably have to lay it on it's side if you take it home in your truck, also. (to keep it from falling). I used cable thru the motor/compressor deck and tied the cable to the wall, ...after I mounted the tank-feet onto a large wooden skid. I tied it to the building air-distribution system using a lever-ball-valve and flexible 3/4" hydraulic hose.
I have the same compressor in my shop, or at least really close, it is a CH, twin cyl. single stage, cast iron.
I am pretty sure it is a 6.5 HP, I got it on sale at Home Depot, something over $300.
I have been well pleased with it.
Well, except for the pressure switch, which fell all to pieces, and then points started welding themselves.
A good quality pressure switch, and good to go.
Dunk, I found out that CH grossly misrepresented the HP ratings of their compressors, as did most of their competitors, until federal regulations changed a couple years ago. Mine also claims to be 6 hp, but in fact it's less than 3. I contacted CH about this and they dutifully replied ...over several emails requesting model number/serial number info, etc etc ...in an obvious effort to delay/discourage me from finding out the truth about their marketing claims when they sold the thing to me. Their legal dept finally got involved and quoted some engineering formulas which were too oppressive/sufficiently confusing so as to dissuade me from further discussion with them
Bottom line was that up until a couple years ago they rated their motor HP based upon start-up wattage...not running-wattage of the motor.
In any case, the actual HP is quite a bit lower than that originally claimed.
Edit to add: The decal on my unit claims 6 hp on the unit assembly. The actual elect. motor datatag says :
HP- Spl
Volts - 240
Amps - 15
One hp equals 746 watts. So the math 240 X 15 = 3600 divided by 746 = 4.8 hp.
But CH actually owned up to the statement that in reality it is only a 3 hp motor, based on continuous power.
