Air conditioning experts 2
fixerupper
Back on June 3rd I asked for some advice on why the air conditioning kicked out on the 1086 when the engine was run wide open. I finally had time this morning to check out the condenser and radiator. Both were reasonably clean but I blew and washed out the condenser and radiator anyway while I was in there. The sight glass on the receiver dryer was showing bubbles and the air conditioning kicked out at part throttle sitting in the shop. I added two cans of 134 and that got it working again with no bubbles in the window. It looks to me like I have to go on a leak search next time the shop is available. Thanks for the advice..
GOOD LUCK finding leaks.
Years ago I worked on window AC for myself.
I had a leak I couldn't find. So I removed all
electrical wires, controls, fan motor and put AC
in swimming pool. Found the leak in the center of
the evaporator coil. I pealed back aluminum fins
and soldered the leak. The pin hole was a defect
in the copper.
I had a 10 year old Chinese dehumidifier. Removed
everything and put it under water. Hundreds of
pin hole leaks. Every elbow in evaporator had
many pin holes. I scrapped it. Copper tubing was
paper thin,
GOOD LUCK FINDING LEAKS
Thanks for posting the update!
GLAD to hear it worked out for you, but for future reference. by the time the sight glass is completely free of bubbles in a converted to R134 system it is OVERCHARGED due to the difference in how the original R12 and the conversion R134 "behave".
This is a known "FAQ" for converted mobile AC systems.
We all like all the cooling we can get, but for longevity being slightly UNDERCHARGED has worked out better in my experience.
Having a little less cooling from a system that continues to work is better than one that blows a hose or breaks a compressor, IMHO.
The lubricants that are used with R134 aren't as effective in older compressors originally designed for mineral oil and compressor life MAY be shorted, ESPECIALLY when "worked to the max".
Every spring my pu would need a shot of 134A. I took it to a friends shop and told him to find the leak. He told me it was fine and had set all day with a vacume on it. I opened the hood one day to check the oil while it was raining, and watched the schrader valve bubble! Hard to see those with a gauges hooked up!
