Air intake hose question
Mike Fitz
I would like to find a replacement middle intake hose for my Massey180 with a perkins gas motor, I'm not having much luck finding a part number or a source for it.
Thanks for the part number! Ya' someone sliced the hose to spray ether to try to get it to run, I glued the hose and wrapped it in tape to hold for now, but with a fresh coat of paint on the tractor I thought it would look kind of tacky.
If you have a parts store you generally use, take the hose in hand and ask if you can compare to the hoses they stock. You may find a longer radiator hose with the bends you can work with and cut it down. Done it a number of times. A short stub of exhaust pipe between a couple pieces of hose can work as well.
I like to wander around my local "pull and save" with the hose in hand and look under a lot of hoods until I find something that will work. You'll never find a perfect fit at the parts store, or at least it will take you a lot of hours. Be kind to your local junk yard owner and it might be free. steve
