Air Power Grease Gun for Tractor
Don't think it matters. I have one I use on an un-regulated outlet from a 175 PSI compressor without issue, tho I don't recommend using full pressure all the time. As long as there's enough to cycle the gun you should be fine.
i got an air powered grease gun from a friend. How many pounds of air pressure should I use with that?
I brought one from HF are a cheap one from somewhere. I had to regulate it to 90 PSI are it would blow the seals. I brought a Lincoln from NAPA its a little over 20 years old I plug to to 175 psi. I would agree regulate to 90 psi would probably save the gun from failing.
I have one compressor that only goes to 65 psi, mine works fine on that. I would imagine they are designed to put out about 5,000 psi with 90 psi of air, that's what most air tools are rated at.
