Allan in NE, REPORT...
Bob
Last we heard, you were going out to check the IP on the Allis combine, but you never posted back!
What'd you find???
I "think" ya nailed it, Bob.
Started at the fuel tank and worked my way forward checking every blessed thing I could find.
When I pulled the cap on the pump, it didn't show a lot of gravel, so I went ahead and pulled that timing cover window. She's definetly coming unraveled 'cause there were a lot of black plastic "specs" in the fuel.
Biggest thing tho was that the return check was leaking back (probably from that crud).
Cleaned it all out the best I could and put in the new updated valve. It seems to have cured it (for now anyways).
If I can just keep it running long enough to thresh this little dab of seed, then I'll yank that devil and go thru it later.
Thanks for your help,
Allan
