Allis B governor spring
Dkalsow
Hi, Does anyone have a picture of how to hook up the governor spring on an Allis Chalmers B tractor. Right now, I have one end in the throttle cable's little hole and the other end on the last bolt on the right for the manafold. This pulls the troll backwards. Is this correct?
Dale
Dale
Dale
That spring is supposed to go basically straight UP, not forwards or backwards. In fact, you can remove it and get along without it unless the governor surges too much.
Well then, leave it off. Someone probably has the wrong spring. I'm also suspicioning the governor isn't adjusted correctly and that's why that incorrect spring is there.
