Allis B rear seals
I asked a question a couple weeks ago about replacing the rear seals on my Allis B & Dennis K from WA responded with good instructions. I still am having issues - I got the seals out, but cannot get the key out of the keyway in the pulley shaft. I tried to tap a small screw driver under the end of the key & just cannot get the key out. Dennis had suggested to use a speedy sleeve on the shaft - I can't get a speedy sleeve on the shaft without getting the key way out. The shaft has a spiral groove in it where the seal will sit - with out a speedy sleeve will that groove hurt the new seal? Thanks - Old Wheels
Sounds like a front seal rather than the rear seal.
No key on the rear which would be next to the flywheel.
Get tuff with the key and use a dull chisel. That key is a hardware item, you can pick up a new one. Just don't damage the crankshaft. Hit hard enough it should pop out.
The spiral groove will not damage the lip seal but will seep oil after you shut off the engine. Speedy sleeve is the best but JB Weld will plug the groove from seeping if it has been smoothed properly.
The spiral groove is to draw the oil back into the pan while the engine is running with the cork seals. The wider width of the cork seal keeps it from seeping oil as long as the cork has not dried out. Most if not all cork seals had a dirty oil witness back of the crankshaft pulley anyway. The lip seal without a speedy sleeve or the spiral filled will have some oil drips.
Thanks for the advice, Dick - just wanted to clarify that I meant the seal around the PTO in the rear and the seal around the shaft on the pulley shaft. If I was to get tough on the key with a chissel would that be hard on the bearing that is on the pulley shaft? Would you recommend filling the spiral groove with JB Weld -- would that be enuff or would you need a speedy sleeve also? Thanks in advance for your advice. Old Wheels
You need to buck up that shaft before hitting on it if it worries you- also makes hammering more effective. Often seen in old books, "bucking up" is simply supporting the shaft on the opposite side so it doesn"t flex. Pressure on the bearing is then a non-issue. Use blocking, jack, etc-anything solid to support it. Then whang away!
I just did the same thing on mine. I couldn"t get my key out either. I tack welded a piece of flat stock to the key and knocked it out then ground it smooth again.
I also filled the grooves with JB and then installed the speedy sleeve. Working good for me so far. No leaks.
Hello Old Wheel, The bottom of the key groove is rounded or moon shaped, so if you rap it with a punch on one end as Dick suggested it should roll up out of the groove. If it takes hard hits, a buck as jms suggests would be good too. New keys are available at hardware stores or auto parts.
JB weld would fill the groove but I'm not sure you could smooth it up good with the shaft in its current position.
Sounds like you're moving along. Good luck.
Dennis
I have good luck with those keys by pounding one end down flush with the shaft and grabbing the exposed end with a set of sidecutter pliers. They have enough leverage to yank them out normally.
I went through a similar problem last fall with the axle shaft on my B. As a last resort you can carefully grind the key out with an angle grinder and replace it. I don't recommend this, but when everything else fails it's another option.
Good luck.
