Allis C Rear Wheel Issues
bisenberger
A few weeks ago I literally drove out of my rear rim. It turns out that one of the stop pads was gone and one of the fingers on one of the eccentric clamps. I repaired the rim adding a new block and got a new eccentric clamp. I have reinstalled and I just noticed that the hub was somewhat loose in the rim. Can somebody explain to me how I might get these tight? The two eccentric clamps have special bolts in them but I have not been able to determine that they actual do anything. It seems like the two plane clamps just go in as they do and the eccentrics should apply pressure to the rim when they are tighten to make a positive connection and not allow the hub to rock in the rim. Should I get some new eccentric bolts? How do you tighten the hub to the rim?
The 2 that are the eccentric need to be side by side as are the other 2. Then you have it up on a jack and have the two non eccentric at the top or with out jacking it up have them at the bottom. Turn the 2 eccentric bolts till good and tight then tighten up the nuts while holding them tight. I've never had to replace an eccentric bolt on the Cs I have
your clamps are worn... Take a couple of them and grind clean in the GROOVE VEE that fits the rim.. Weld in several beads of rod to buildup 1/8 inch taller than they are now... Two if them should be enough.. Don't matter if you use the fixed or adjustable ones... Normally the two adjustables go next to each other ( not 180 degrees apart).
Another tip if you are using two eccentrics. Tighten them in opposite directions and try to keep them as even as you can. Usually the heads are indexed with a cross. As an example, if your eccentrics are on the top with the tails of the crosses both pointing up and toward the center line, rotate the one to the left counter clockwise and the one to the right clockwise. The main thing is to keep them close to equal.
