Allis CA Hydraulics
wolfgang50
I finally got the lift arms to go up...but now can not get down......messed with this arm at very bottom of hydraulic pump..could hear some gears meshing and then I could pressure lift arms back down. The lever I messed with looks like it might go to some linkage to drawbar...which is all missing. By the way if lever under seat is all the way up...are lift arms up. I have no manual, etc. Appreciate the help.
The lever under the seat that has the "curl" in the metal to hook your fingers through must be up to turn on the PTO which in-turn allows the hydraulic pump to work. Of course the straight lever is the hydraulic control lever. There are three different settings you can do to the hydraulic system by turning the setting adjustments in or out in various combinations depending on what you are trying to do. If your CA is a newer one - I'm thinking newer than a '52 - the draw bar is integrated with the hydraulic via the Snap Coupler. The Traction Booster system is all tied into the hydraulics and there is a specific way to set all the tensions on that system so they work right. It is not hard to set up, you just need the correct steps. Your best dollars spent is to get a service manual or operators manual through Yesterday's Tractor or sometimes on e-bay. Be sure your oil level (dip stick is on the side of tranny on clutch side) is full as there is a common oil sump for the hydraulic and tranny/diff.
Thanks Sel Larsen....my tractor is a "53. I do have a service manual from IT but it does not show very good photos of all the "parts",etc. Think owners manual may be the ticket.
Hey Wolf..If your IT manual is thier "Shop Manual" (IT part#AC-11), look on page 95 paragraph 330-332. It gives a pretty good description. If you are buying a manual, the Operating Instructions & Parts Illustrations for Model CA Tractor published by AC Form TM-46D gives an even better layout on pages 25-30.
Sometimes you can find that one on line (E-Bay) along with the actual AC printed Shop Manual which is pretty thorough. Also, check with Tony's Tractors at 503.767.3660, or [email protected] Good luck.
