Allis Chalmers 5050 tractor
Rob VA
I’m looking for some good fuel filters to replace the one old ones. I just brought this tractor . I see there are two one on the side tof tractor and another one on top under the hood ..are they the same filter ?? Thanks
If you plan on keeping this tractor around I suggest you invest in at least the Operator's Manual and Service Manual right away.
Below is a link to the AC5050 parts book so you can find the filter parts numbers and cross them to a brand you prefer. It looks to me like they used the same element in both the primary and secondary. I didn't notice a third fuel filter. Can you post pictures of all three?
AC 5050 parts book
i was just looking for some fast filter brands(numbers) that people were using . thanks Harry ill try the 3166. napas right down the road . the tractor only has two fuel filters as i stated in first post. .. is there a screen of some sort in the manual fuel pump that you prime with . that i need to clean also??
I can't answer your question on whether there's a screen in the lift pump. But it's fairly common. If there's a little cover you can remove, it wouldn't hurt to check it. The only downside would be getting it sealed up again.
