Allis Chalmers B
Tractor Rob
I have 4 wheels to take off two Allis B's. I know from past experience the clamps and cam bolts are going to stick to the center hub. Anyone know a good trick. Must be an easier way than what I'm doing ie. brute force, WD40, PB Boltbuster & trying to hammer the cam bolts out of the center hub.
soak with penetrant. i then use a breaker bar on one side with a 1/2 inch ratchet on the other side. socket and extension on each. if you got a good air impact, that can help.
Pb Blaster will work.
I use a bottle torch on bad rusted bolts and put a little heat on them to warm the bolt/nut then spray them with Pb Blaster and it works.
You can use ATF in a sptay bottle also.
Just warm the bolt and spray and the heat will draw the fluid into the threads.
