Allis Chalmers C Starting Problem
Petah989
Hello, I have a 1941 Allis C and it is having problems starting. I know its not a fuel problem it is entirely electrical related. But the specific problem I am having is that with everything hooked up nothing turns over at all. I took the starter out and turned the key and the starter did spin up. Although when I put the starter back in it would occasionally turn the engine a bit but the voltage would read only 2-6 volts at max. So I'm not sure if the starter is bad or if it is the magneto. I doubt it to be the magneto so I think it's the starter though I don't want to buy a new starter and find out that's not the problem. If you need any clarification please let me know. Thanks, Peter
Before you buy a starter Id check allllllllll cables and connections and terminals and grounds. Remove, clean and wire brush bright n shiny each and every battery connection and cable and ground and starter switch connection.
Sometimes a ground cable to a piece of thin rusty sheet metal doesnt work well, maybe run the groudn to a starter bolt or heavy frame member somewhere near the starter.
Next the start switch may be bad and has burned carboned pitted resistive contacts.
Just because a starter spins free with no load (like off the tractor) does NOT mean its okay under a load!!!!!!!!
If when you try to start it the lights dim wayyyyyy down and/or the battery voltage drops down drastically, the switch and connections and cables and grounds are likely okay so the starter itself may indeed be bad or ITS MECHANICALLY STICKING JAMMING INTO THE FLYWHEEL
If when you try to start it the lights hardly dim and the battery voltage doesnt drop much then I suspect a bad switch or bad cable or ground or connection, althoug it could still be a starter problem such as worn brushes etc.
Check cables and battery connections and switch connection and grounds AND SURE THE BATTERY IS OKAY AND FULL CHARGED????
John T
I thought it was the battery but I had it hooked up to another machine while running and the same problem. And it does work fine when I handcrank it so Ill check the terminals and ground because I have a feeling it might be a problem with one of the ground cables. Thanks for the help , Peter
The only ground cable on a Model C is the battery ground cable. The starter does not have one. It grounds directly to the frame- that"s why it needs to be free of rust, etc.
The starter grounds with the locking stud. If it grounded where it slides into the torque tube you would never have to tighten a battery clamp.
