allis chalmers CA 12 volt conversion
Make that CA think it's a Farmall, if it's a battery ignition & uses a right-angled Delco distributer. (They were also used on Farmalls.) A guy called John T has a great series of diagrams over on the IH board on how to do to a conversion using a 10si Delco. He has them for both battery ignition and a Magneto.
https://www.bb-customcircuits.com/apps/webstore/
Steve's is an AC man, has everything you need, instructions the works.
One wire systems all leave the alternator in a almost on condition. This can drain the battery (in some cases in a week, in others a couple of months. The best is a 3 wire system that mimics the automotive application and provides quick start to charging. The only real issue is getting the pulleys lined up. For a physically smaller install, use a Hitachi 14231 alternator. They use the same wiring, with the S terminal same as the Delco #2, and the L terminal the same as the #1 terminal on Delco. Jim
IH diagrams from Bob M
Get one of the small size alternators so it won't hit the steering arm.I like the one wire alternators easy to use and 99% of the negative stuff you hear about them I have found to be false like draining a battery, just cranked my David Brown 780 the other day with a one wire alternator had been sitting since last October fired right up no problem.
