Allis Chalmers D14 hydraulics
WMRICH
First time to ask this , I have a Allis Chalmers D14 with a trip bucket loader, I would like to install a PTO driven Hydraulic pump to change the trip bucket to a Hydraulic cylinder operated bucket, and also use the pump to operate the loader, Will I need a separate oil tank for this or can I route the hoses thru the tank on the tractor where the hydraulics run the lift arms ? Thanks
Old is right going to be hard to keep you fluid levels right, seperate tank will work a lot better.
And if I was going to di a separate pump I certainly would consider going up front either to the end
of the engine crank or belt driven . Would make for a much better set up.
(quoted from post at 16:16:43 02/16/21) 4-5 gal tank should be just fine. My Ford 841S has a loader on it and the tank is 4 gal and has worked just fine for decades
Do you use a belt driven external pump/ and if so what kind do you use and where can you get one, Thanks for your replies.
(quoted from post at 17:26:11 02/16/21)
The usual pumps for loaders are shaft driven off the crank. Belts are more prone to slip unless you have a dedicated pulley to drive the belt. Check out the answers you got when you asked this a few days ago in the Allis forum. DrAllis gave you another option as well.
