allis chalmers road grader
gtank101
My name is Greg from Ca I have a DD-1259 road grader with a 230 buda diesel engine i am trying to locate a cylinder head Cause this one looks to have some stress cracks in it they dont look bad but if could find one that would be Awesome any help is appreciated thank you in advance
if the cracks are just lnside of the nozzle bores and the air cells on the bottom side of the head don't worry about it.
They ALL are cracked like that. Until you start leaking coolant thru the cracks or have valve seat issues, continue to use it.
You can have that head welded up if you really need to. It can be an expensive proposition, but it may be your only option as even if you could find another engine, its head may be in even worse shape! You'll have to find a machine shop that specializes in this type of work and one that has hopefully been around for a while so they have some experience in dealing with old, abused and well-seasoned cast iron.
But yeah, as long as the head seals to the block, hairline cracks that dont leak coolant into the crankcase or blow your radiator cap off aren't really a problem.
So far...
At least you have a nice walkway (the tandem drive gearboxes) on either side of the engine to do any repairs from!
