Ken in IND
My HD5 starts to flutter and lose power after working it for between 30 to 60 minutes. I thought that it may have been heating up so I removed the radiator to check it out and found it to be in good shape so I cleaned it good inside and out. Removed the water pump to be sure the impeller was operating as it should and it was. Removed the oil cooler, soaked it in solvent and cleaned it good. Found no thermostat in it so I installed one. Replaced all only to have it do the same thing. When starting cold there are no bubbles in the radiator to indicate a head gasket problem and no oil in coolant or coolant in the oil. I have changed oil and filter as well as the 1st stage fuel filter. The dozer runs good for about 30 to 60 minutes and then starts to miss, flutter and lack power. It will do this for a short time and then continue to run good for awhile until it flutters again. As you keep running it the dozer progressively gets worse until it is missing to the point of almost dieing and lacks power to even turn the machine but will continue to run intermittantly to get it back to the barn. The exhaust is white and it doesn't blow any black or blue smoke even when missing. After sitting for awhile it can be worked again until it starts to flutter and miss. If it dies when it is in this shape it will start right back up. I'm at a loss of what the problem could be now.
