allis hydraulics
randy47
I have a freeman loader on my wd45 with a trip bucket . I want to install a 6 foot bucket with hydraulic controls-- the loader now is hooked in the rear remote-- is there any way to plumb this using the tractor hydraulic pump and still have the remote avaliable to use or will I need to hook up a front mounted pump????
Ive seen them hooked up like you want with an aftermarket valve body might slow the movement of the loader down a lil but not totaly sure
Yes you can, but not likely with the valve manifold provided. You will need a two position valve to shift between the two pumps. It is also possible to simple add a valve that is not part of the manifold, but this would have to a three port, two position valve. It would require a pump discharge from both pumps and one port directing flow to the valve manifold(Block).
