Allis Sickle mower
Shimmy
What kind of information? It's a mower and it was made by Allis Chalmers. Nothing special about it. Works pretty much the same as any other pitman style sickle mower ever made.
I did a quick search on google and it appears to be a #3 or a similar model. Parts and repair manual is available on Ebay.
This is meant in all good fun, but why the photoshop job on the picture? Does your buddy live in Area 51?
I probably didn’t something with the picture who knows. I’m not good at this stuff. But he’s wondering why the one way hydraulic line. He’s try to make it work on his ih tractor
Looks like a #3 mower. It was made before 3-point became standard, it's not going to fit on anything but a AC tractor without modification. Unless your buddy is handy with a torch and welder, probably need to either find a AC tractor to hook it to or get another mower.
The reason for the single line cylinder is because it's a single acting cylinder (pressure to lift the mower and gravity makes it go back down).
He’ll need a different hydraulic cylinder. The one on it now is made for 3000+ psi.
You, or someone, photoshopped the entire background, along with some of the details of the mower, out of the picture. Not something a person can do "by mistake." Just wondering what the reason was.
One-way hydraulic because it doesn't need down pressure to lower the mower. Gravity works just fine.
What IH tractor? If it's a letter series they come with one-way hydraulics from factory. If it's a 00/50/60 series, the remote valves are selectable between one-way and two-way hydraulics.
Generally speaking, tractors will work just fine to lower the mower if you simply ignore the missing second hose and just lower the mower with the hydraulic lever. The hydraulic system will tolerate being dead-headed for the second or two it takes to lower the mower.
