Allis WC cultivators
I don't think styled or unstyled would matter. The frame and front end of a WD are the same or very similar (front end castings will interchange) so they might well fit on. The lift may be different and need adapting.
WC mechanical lift, Never heard of a WC with hydrolic lift but would it be possible to put the hydrolic lift from a WD on a WC, I don't know. WD had hydrolic lift.
Styled or unstyled would work perfect. I've seen a manual for mounting the WC cultivator on a WD. There would be some different brackets and I'd assume hyd lift somehow. At any rate, they had provisions to do it.
AaronSEIA
My WD cultivator manual show a conversion kit to mount a WD cultivator on a WC. No way will a WC cultivator mount on a WD, with out a cutting torch and welder.
(quoted from post at 21:06:49 03/04/22) My WD cultivator manual show a conversion kit to mount a WD cultivator on a WC. No way will a WC cultivator mount on a WD, with out a cutting torch and welder.
I think you are right. I had it backwards in my head.
AaronSEIA
