Allis wc serial number
There was a model "RC" tractor, but their serial numbers never went that high and they were 1939-40-41 and streamlined. Unstyled/flat top model WC's were s/n 72,330 and down 1933 thru most of 1938. Don't know what you've got.
It might be possible you are looking at a WC with an RC rear end? The RC rear end had a lower gear ratio to make up for the less powerful engine used, (the B engine) and I think there was one less bearing on the pinion shaft, two instead of three.
(quoted from post at 06:12:31 11/14/22) It might be possible you are looking at a WC with an RC rear end? The RC rear end had a lower gear ratio to make up for the less powerful engine used, (the B engine) and I think there was one less bearing on the pinion shaft, two instead of three.
****** The problem with that theory is they only made about 6,000 model RC tractors and he says the s/n is higher than that. 27,753 is way higher than 6,000.
This post was edited by DrAllis on 11/14/2022 at 05:38 am.
An "RC" rear end works good when you use 38 inch rear wheels and have a pretty stock G-226 or W-226 engine. Strong HP engines use a WC rear end and low gear is right at 3.5 MPH at full throttle with 38 inch rubber.
