Allis WD with Gleaner E Motor
Blight
Putting together a WD with a Gleaner Motor. Does anybody have pictures or suggestions to hook the throttle linkage to the govenor to the carb. Thanks
You change over the timing cover parts to tractor linkage. If you try to stay with the combine design, you have no governor control unless it is wide open throttle. You will not like it that way.
