Heyall, I just bought a '52 WD as parts for my my great-grandfathers, now my Dad's tractor, and once I got looking at it, I think I want to fix the old girl up. There are
some issues for sure, but also some nice parts on it. Right now I am just trying to get it running before I put any real money or time into it. I have worked on a lot
of tractors and machines, but this is getting on 5 days now without success.
So far, I have an excellent spark. Compression is low, but it's low across the board, and has been sitting for a long time based on what I'm seeing. I suspect it will
improve.
I have it cranking on 12 volts. I cleaned the carb but 3 times over, cut new gaskets, and soaked it for a day in lacquer thinner. Blew it out with compressed air and
clean holes with wire.
The bowl fills with fuel, and is free flowing from an auxiliary gas can.
I put my hand over the carb to choke it, and it will fire instantly, run for 1-3 seconds, but won't keep going. I can do this over and over but won't catch. I am still
leaning towards carb issue, because I don't get a flood of gas out of the carb when I stop cranking like I do with my 8Ns (same Marvel carbs). But it's as clean as can
be as far as I can tell. I am tempted to install my known good 8N carb just to see what happens.
I also checked the timing and set the point gap. (not a magneto ignition). The timing was close enough, point gap a few thou off, but not enough to matter.
I don't know if I need to investigate a manifold leak (not drawing fuel up?), or perhaps take apart the distributor drive (timing shifting around?) ... or maybe I am
missing something entirely during carb cleaning.
I'd appreciate a second opinion... excited to have my first Allis up and running.
Thanks!
improve.
Thanks!
