bwilcox
Allis C wouldn"t start . Mag has jumped 1 gear tooth from mag/cam mark . Always started in past with no problem . All gears look good . Cam/crank gear in time . The easiest way to put back in time is to pull cam gear and reset marks . Does anyone know of a reason why they would jump ? Is the mag gear pressed onto the mag shaft ? Could it have spun on the shaft ? How do you get the mag shaft/gear assembly out of the block casting ? I don"t want to have it jump out again . Thanks Brian
