Allmand Bros TLB-25
drhoad
HELP!
need help finding tie rod ends for this tractor it's an early 90s I've contacted Allmand Brothers not much help there as they no longer manufacture tractors
Any help finding or parts numbers would be greatly appreciated
They certainly didn't manufacture the tie rod ends even when they were making tractors. They would have used commonly available, off the shelf parts. You simply have to measure up what you have, and match them up with generic parts online.
thanks for the answer I've been doing that problem is most don't list the specs of their product
I've no idea about your capabilities. Get the dimensions of the tie rod ends you have and then do a Google search for tie rods with those dimensions. If you are unsure of the dimensions you have, take them to a local dealer, any brand, and have them help you figure out the dimensions. Then do the online search for ends with those dimensions.
https://messicks.com/
If the above fails, call Messicks at their 800 number. They will help you find a match if it is possible.
Take the old one off and go to a good parts place usually a mom and pop place they will measure it up and get what you need. Other wise take it into one of the friendly local stealerships and see what they find. Our 574 uses ones from on a jeep not sure or don't remember which model now. I also am cheap and will not pay the cash for the long notched one so cut it off and weld to the threads of a new one I also grind a notch in it if need be.
