almost fires up.....
M n NC
the old 9n is close to firing up.
it's got gas that runs out carb at drain plug
it's got fire to he plugs
it turns over strong and huffs and puffs and almost runs
still a piece of the puzzle missing....
any ideas...thanks to all who comment
If it has been sitting for a while the valves may be sticking. I usully remove the side cover and check to see if all the valves are moving up and down. Add so lube as needs to free sticking valves. compression testing will also show if there is a problem with the valves of rings.
thanks Doug12
it ran well for about 1 hour and then while pulling a load, sputtered and puffed like it wasn't getting gas and then stopped. been sitting for 5 days. at least it stopped under a shade tree :)
wondering if i need to hold the choke closed while trying to start...or if that is flooding the carb.
thanks again
It is important for you to tell us if your tractor has a 6 volt or 12 volt electrical system. The troubleshooting is different based upon the configuration of your engine.
It takes three things for an engine to run: spark at the right time, compression, & fuel in the right mixture. For the moment, forget about compression & concentrate on narrowing the problem down to spark or fuel.
There are three very important tools you always need to have in your N tool box: a 3 inch piece of wire w/ alligator clips on each end, an old spark plug w/ the gap opened to at least 3/16” ( ¼” is better) and a 7/16 box end wrench. (see tip # 50 at the link below) And, you really do need a working ammeter on the tractor; it is a very important diagnostic tool. With these tools, you can quickly narrow down most N problems to spark or fuel.
Next time it stops, check quickly for fuel then spark. When I say quickly, I mean get off the seat, grab the tools & do it right then. Do not wait a minute or two. First, check for fuel. Get a can & put it under the carb. Remove the bolt in the bottom of the carb; as long as the fuel is turned on, you should see gas flowing out of the carb. Let it run for at least 30 seconds. If it’s a dribble, or runs for 5 seconds & stops, or none at all, you have solved half the problem: it’s fuel related. If gas flows well out of the carb & only stops when you turn it off at the sediment bowl, chances are very good it’s not a fuel problem. So, next, turn the key on, crank the engine & look at the ammeter. What is the needle doing? Does it show a constant discharge, no movement at all, or does it move back & forth slightly? Next, get the old plug, ground it to a rust & paint free spot on the engine, turn the key on & crank the engine. If the spark jumps the 3/16” gap, you probably don’t have a spark problem. If it won’t jump the 3/16” gap, you have a spark problem. If the ammeter needle shows a constant discharge, or doesn’t move at all, that also tells you that you have a spark problem. Jump the ignition switch w/ your jumper wire & see what happens. If it runs, you found the problem. If it doesn’t have spark after you jump the ignition switch, post back for more info on further troubleshooting. (and do not forget to turn the ignition switch off; see tip # 38)
If it does not have gas coming out of the carb at a steady stream w/ the bolt out for at least 30 seconds, you have a fuel problem. First, remove the gas cap. Your vent could be clogged & it vacuum locked. If that doesn’t work, tap the carb bowl w/ a hammer handle in case the float is sticking closed. (don’t whack it w/ the head of the hammer; you can crack the bowl). If you still don’t see gas flowing, the N has three fuel screens; one in the brass elbow, one in the top of the sediment bowl & one on the stem of the sediment bowl in the gas tank. Check the screen in the elbow & the screen in the top of the sediment bowl. (don’t worry about the one in the tank) Both probably need to be cleaned. If you have the fuel knob turned on all the way, & 1 gallon or less in the tank, it may be trying to feed off of the reserve inlet which is probably clogged. Only open it 2 full turns. Put at least 2 gallons in the tank. (and do not forget to turn the gas off; see tip # 9)
There are ways to check for spark & fuel that work & ways that don't. For example, having gas to the carb is nice, but having it past the float is what counts! That’s why removing the bolt in the bottom of the carb is the way to do it. And, same thing w/ spark at the plugs. Some folks think that checking for spark means pulling a plug wire off & looking for one. Well, it's the distance the spark jumps at the plug that gives you the info you want. It takes about 17kv to jump a 3/16" gap & 22kv to jump ¼” in the open air, so that's why you need to use a spark plug. Or, a store bought plug checker (on the left in the picture). Remember, it’s 14psi outside of the engine & about 90psi at a 6:1 compression ratio in the cylinders & compressed air creates electrical resistance, so you really need the 17-22kv to fire the plugs when the engine is running.
Yea, holding down on the choke is a real good way to flood it.
50 Tips
thanks Bruce
as for fuel at the right mixture, how does one determine if the fuel flow is at the "right mixture"
am assuming the adjustment screws on the carb determine "right mixture"
i believe mine are backed out one full turn from closed...sound right ?
thank you
woo hoo !!
she's running ! my guess is the gas was flowing from the reserve and not flowing steady. add 1-2 gallons and stayed off the choke and she fired right up...love that sound !
thanks for all the help !
(quoted from post at 13:58:35 05/22/11) woo hoo !!
ruce, seems like you need to add to your list, 'put gas in tank'. :wink:
you're right 'bout that JMOR :))
dang...it measured 1-2" on my gas stick, oh well
its back to the drawing board as it won't start again after sitting for about 1 hr :(
i love her anyway :)
(quoted from post at 14:53:29 05/22/11) you're right 'bout that JMOR :))
on't just look for a little gas out of the carb bowl drain.........it needs to flow enough to fill a pint jar in 2 to 4 minutes (less time is fine).
