almost stuck engine
Well the gremlins are alive and well in my shop. I've been battling the fuel system on my O14 for a while trying all the advice I've gotten here.This morning I go out to the shop and I can't hardly roll the engine over it's really tight! went after the usual suspects,fan not seized ,fuel pump is off, starter removed ,clutch not engaged , not in gear why would this engine get tight overnight? Thanks in advance
i had a farmall cub do this. when i bought it , engine would turn easily. i cleaned plugs, points, air filters, etc.. then i added coolant to radiator, with the idea in mind to start engine. engine go so it would not turn over. tore motor down and it had a coolant leak on # 2 piston.
Put a couple squirts of light oil in through each spark plug hole. Since you have been "battling the fuel system", I guess you have tried starting it several times since it has last run. If so, you may have washed all the oil off the cylinder walls.
if you step on the clutch while having it turned over with the crank, and its still tight i would be checking the rod brgs. like dont know if this a fresh overhaul or what. sounds like tight brgs that are galled.
Thank you, Jim Becker you nailed it. I put some oil down the cylinders let her set for a bit . She rolls over pretty good now. Thanks again Chuck K.
