alternative engine
Drak
HIALL, I have a AC WC with engine issues and was considering to buy a secondhand engine for it, what would be the best up-grade engine to look for ??that would fit, my wc is 1935 unsettled, your help would be much appreciated in this matter.
John
Not an AC guy,but I think a WD or WD45 engine would be your best bet,especially if you want to be close to 'factory'. However,if you want something more 'exotic',like a V8;diesel;inline 6,or..... Your immagination is the only limiting factor.
One time I found a LeRoi 50HP engine, about 226cid I believe and it bolted right into a WC. I used it on a Gehl mix-mill and ate up the transmission gear that drove the PTO. So, if you up the power in your WC, be careful how you use it.
The E Gleaner will fit, you have to cut a small notch out of the frame rail,maybe a 1/4 deep,X a inch long, to make room for a housing, on the right front corner of the WC, other than that it fits nice !!!
