Alternator cooling fan?
mdm1
Location
Onalaska,WI
In a 12v conversion on a tractor will the alternator over heat if you don't use the exterior cooling fan? Being in the open I was just wondering. I have a project that may not have much room and the fan might be a problem.
This post was edited by mdm1 on 12/30/2022 at 03:56 pm.
A couple things I would think about: 1)All alternators have cooling fans. 2) Heat is the death of electronics. What are you thinking about using for an alternator ? I think it is a Denso that is smaller than a Delco 10si. For sure Subaru alternators are smaller and put out plenty of power.
Kinda what I thought. I'm using an Hitachi. It does have a fan. When I put it on my G everything looked and worked good until I put the hood on. I don't want to cut the hood. I will look at the mounting bracket and see if I can redo that so maybe get some clearance. First time I ever did this so learning experience. I will be redoing to make sure the fan is there. Thanks for reaffirming what I thought.
its not going to matter. them alternators in vehicles nowadays are tucked in there tight then a cover over the engine just like an oven. i
sure dont see how an alternator on a tractor in the open with it being a problem with no fan. plus the rad fan would be sucking air through
them also. the alternator gets warmed up when its charging at a high output like with a dead battery.
You could probably get by without the fan on a tractor as long as there is
not a continuous draw, such as an air conditioner, and it was not used to
recharge a dead battery (which should never be done anyway).
Alternators are pretty tough. Using an alternator with a fan on a working
tractor will quickly pack it with dirt and grass, blocking most of the air
flow anyway.
Your tractor will draw only a small fraction of the electrical load that alternator was designed for. I doubt it cause the alternator to fail if you remove the fan. But if the fit is so tight removing the fan will make a difference in clearance, I think you'll need make some changes to the setup. Fan belts stretch, and you need a little room for adjustment.
Here is what I decided to do. I took the alternator off and redid the mounting brackets. Put the fan back and got a different belt. It works as it should now. I feel better putting the fan back. Thanks for all the suggestions and ideas.
