he excite diode is to prevent the alternator's diode trio from feeding the ignition & keeping engine running after you turn key off & is NOT related to any draining of battery when all is off. ALL 10si regulators whether one wire, two or three wire have a tiny always present drain of from micro amps up to a little over a milliampere into the sense terminal. I have measured several and all are within this range, but haven't measured all that exist in this world. Such a low drain is in fact so low that the battery will self discharge on the shelf by the time this tiny drain would discharge it....on the order of years, not weeks! If discharging in weeks or months, then something wrong elsewhere as in battery or a bad (not normal) alternator. Some one wire VRs will allow charging to begin at lower rpm than others. Once they reach charging rpm and you slow down, they will keep charging even. At the slower rpm.....they don't just drop out.(quoted from post at 10:54:09 09/29/13) crazyllocha
I have forgotten a lot of what little I knew about electronics "back in the day", but here goes:
soundguys hookup only requires the diode to handle current in the field wire which isn't too great.
The one-wire hookup that I commented on would require the diode to handle the [b:d7078ec243]full[/b:d7078ec243] output of the alternator, to keep current from bleeding back through the alternator when it isn't charging.
A diode is just a "valve" that only lets current flow in one direction, in this case [b:d7078ec243]out[/b:d7078ec243] of the alternator.
Maybe SG or old will explain why the alternator would bleed off the battery when not charging - I'm not sure how that happens. (That is probably why [b:d7078ec243]old[/b:d7078ec243] commented that the one-wire alternators caused more trouble than they were worth.)
Myron
ust one more "tid bit" as to a 'good' alternator 'drain' not being a problem: Modern vehicles with a dozen or more microprocessors/computers and the memories to 'keep alive' drain the battery at a rate of 30 to 50 times the rate of a good alternator. So, then we are talking months instead of years.(quoted from post at 21:05:34 09/29/13) Thank you very very much for the edification Myron and Jmor.
The milliamp drain makes much more sense now. And the diode explanation now clicks years and years of seeing them on computer parts and their placements. Sort of a back flow preventer valve on an outdoor water spiket or garden watering system.
Seemed weird to me why so many auto engineers would let car batts get drained without changing or adding something. The milliamp draw version is common on motherboards draining the Cmos batteries when completely unused and not installed. Like Jmor said, more drain would be likely other issues, now that I have a better understanding of issues.
Thank all three (you too Old)
Mikey
