Alternator/Regulator
RockRon
The alternator on the Deutz D4006 seems to have gone bad. By the book, it was 14V 18A. When the "suitable replacement" arrived it's listed as 12V 33A. Here's the question...since this has an external regulator, do I need to replace the regulator also? I'm thinking the regulator is just going to maintain 12V regardless of the alternator, but don't want to make a potentially expensive mistake.
Are you SURE the reg is OK, and the alternator only is at fault?
GENERALLY alternator regulators regulate voltage only, NOT current, (as opposed to DC generator charging systems) so it's likely IF the alternators are the same make/style/hookup you can swap the alternators without needed to change the regulator.
Of course, if doing that lets all the smoke out of the electrical system I disclaim ANY responsibility and you'll need to order one of these kits:
<img src = "http://www3.telus.net/bc_triumph_registry/images/Smokekit2.jpg">
"Unlike the cheap, far-eastern replacement DIYsmoke offered by the "usual suppliers", this kit includes a filter to ensure that all the smoke is of consistent size, It has been our experience in our shop that the reproduction Taiwanese smoke is often "lumpy", which will cause excessive resistance in finely-engineered harnesses and components. This is often the cause of failure in the repro electrical parts currently available, causing much consternation and misplaced cursing of the big three suppliers."
<img src = "http://www3.telus.net/bc_triumph_registry/images/smokekit.jpg">
