Alternator testing questions UPDATE
GP,
A thought. My ford and farmall came with alternators that would charge at an idle.
Replacement alternators I now have to rev the engine before they charge. After the alternator gets excited, I can slow the engine and they continue to charge.
Do you have to rev the engine to excite the alternator??
One of my tractors had one of those store bought "alternator plugs" on it, plugged into the no. 1 & 2 terminals. You always had to rev the engine before it would charge. I took it off and just wired into the terminals directly with a diode like all the diagrams show. Ever since that it begins charging as soon as I start the engine.
Long boring story here.
George the needing to rev part might have to do with the amount of residual magnetism held in the Alternator. An alternator with a higher amount of residual magnetism will start charging at a low RPM. I learned about this the hard way when I was wrenching on combines. The owner bought six new combines. A couple of them were intended to be sold in California but were instead sold here in Iowa. The two California combines had internally excited alternators that did not need to have voltage shot into them from an external wire to start the charge. The other four combines had common old externally excited alternators like the ones on tractors. Why the difference between the 49 state combines and the California combines I will never know. Combine alternators used in 100+ degree temps don't last long. Chaff sucks up against the air intake screen blocking it and they overheat. I was putting externally excited alternators on combines that called for an internally excited alternator thinking they were all the same. The internally excited combines did not shoot a voltage charge into the alternator to excite it when the combine was started. The wire was there going to the alternator, it just wasn't energized. Those two combines needed to be revved way up first thing in the morning before the alternator would start charging but they did charge. There was some magnetism left in the alternator from the previous day and this was enough to get it going. After that first rev the alternator was good to go for the rest of the day. As the alternator got some age on it the alternator would not hold magnetism overnight so the alternator would not pick up and charge first thing in the morning and the combine was dead in the water. Nothing on that combine worked if the computer did not sense pulses from the alternator. It just sat there with a running engine. We lost many hours out of those two combines from an alternator that would not charge at startup. We had to go to a Cat dealer to get them and Cat dealers were few and far between especially in the western plains. They were $1000 dollar Bosch units. By the way, the Cat Lexion mechanics did not know about this difference and all of the parts men except for one did not know.
Finally one day my patience ran out and I said to heck with it and ran a jumper wire to the excite terminal on the alternator when one of them would not pick up and charge in the morning. Bingo! It came to life and charged. I was afraid of blowing the $5000 computer board from back feeding by doing this but I lucked out. Eventually I found out the only way to discover if the system was internally or externally excited was to lay on my belly across the valve cover of the engine, a cool engine by the way, hang my head way down behind the backside of the engine and with a flashlight look at the engine serial number. I could not tell by looking at the easy to read combine serial number. I don't have the wisdom to know how and internally excited alternator excites nor do I know why this is a California thing. Everything going to California is different so why should I be surprised?
