There isn't one. Guys on here can tell you how it's done and show you pictures, but there never was an alternator installed at the factory, so there is no diagram.
Donovan from Wisconsin
Remove generator and regulator along with ARM and Fld connecting wires
Connect BAT wire from regulator to output of alternator
If regulator had an L terminal, it fed power to light/ignition switches. You can also connect it to the alternator output.
