The amp meter is not showing charge when I start my 52 IH C.It was converted to 12 volt in the past but has been sitting for 6 years in a dry storage area.
Could the brushes be stuck? Also,being 6 volt system before will the same amp gauge for (6 volt) still work for 12 volt or should this be a new one for 12 volt.This one does look new but what should i look for here to check?
If it's a one wire alternator try reving it up. It might need somewhere up around 1600-1800 RPM to get it on line.
And AMP is an AMP, whether 6 or 12 V. However if it was a 6 V positive ground system and was converted to a 12V neg ground system the AMP meter leads might need to be reversed. Votlage is not an issue with the amp meter but polarity is.
To verify if your batter is charging read the voltage accross the battery terminals. If charging you should read around 14 volts with the engine running.
one thing you will find with your amp guage when it works is it will peg itself out for a few minutes.you had about a 15 amp generator now you have about a 55 amp alt.
If it's converted from positive ground to negative ground the amp meter will most likely read a discharge if the wires weren't switched in the back side of the meter. It won't really be discharging but just showing because the current will be reversed in going thru the meter. Hope this makes sense.
Make sure you are getting power down at the battery terminal on the alternator by using a test light or a volt meter. This would be the first thing I would check.
Let us know what you find.
John
Also if it is a "1 wire" alternator, it may need a "field flash" if it has been parked that long.
To do a field flash, remove the cover over the regulator plug terminals and momentarily jumper the two regulator terminals to the BAT terminal on the alt rear with a piece of insulated wire.
Do this with the engine running 1/2 throttle or more.
Using a $2 replacement auto parts store regulator plug with both leads stripped about 1 inch and wound together. Less chance of shorting the jumper wire to the alternator case.
I think there is a D shaped hole on the back of the alternator a couple of inches from the alt plug in. If you stick a metal wire in and ground the tab it will full field the alternator("excite it"). This is on all GM SI alt's, its a good way to check it the brushes or regulator is bad.
