Have an old zetor 6245. Czech alt. hasnt worked since I've had it. Fitted a ford motorcraft alternator from 80's model truck. Should the alt read any voltage without any wires hooked up to tractor. Tried hooking up groung wire to block and still could'nt get it to read voltage. Had it checked at auto parts store before installing. Checked out OK. Any suggestions? Thanks Newbie
an alternator has to be started with an excitation voltage before they will start chargeing. I think that year ford alternator either used a resistor/idiot light to excite the alternator or direct switched 12 volts to the regulator to get things going.
