Ambac on 220
kip1456
What all would I have to change to mount an ambac injection pump and lines off of a L3 gleaner combine with the 670T motor on to my AC 210 or 220 tractor with the 426 motor. Is it a bolt up or are things different in the front cover and idler gear?
Major changes needed, Ambac M100 pumps turn engine speed, Stanadyne/Roosa DM pumps turn 1/2 engine speed. Can be done if you have all the front gears and cover parts needed.
I saw one done at a tractor pull. Internal gears remain the same. The idler gear (dual gear) just uses the rear gear instead of front and rear. Seems like he had to remove the engine oil cooler to get it on the engine?? If you do that, there is a blocking slug that has to be removed or there's no oil pressure to the main oil galley, ruining the engine in short order.
