American Bosch psb pump
AndrewJ
Just curious if there s any injection shops out the that can still test a psb pump? So far up here in Saskatchewan Canada I haven t one one anywhere near me that can.
Nobody will put a pump on a test stand unless it has been
totally overhauled. That will contaminate their system.
And the psb pump all the parts are obsolete. So if it was
sitting in a tractor and the engine was turned over you
just broke the rotary shaft. Means pump is junk. Do give
info on your pump. Massey Harris , Case, Oliver, Minnie
use this pump. On my 900 case I pulled the pump off
before turning the engine over. And yes pump was stuck.
I took it all apart and loosened it up put if together and
started the tractor after it sat for 30 years.
