woodysgarage
Would someone please tell me how to wire a 6 volt am gauge in a 1953 jubilee tractor. The am gauge I now have has a connection for Lights and Battery.
(quoted from post at 09:23:55 05/04/22) Would someone please tell me how to wire a 6 volt am gauge in a 1953 jubilee tractor. The am gauge I now have has a connection for Lights and Battery.
uch better markings, +/-, as in industrial ammeters because then regardless of POS or NEG ground, it can be wired right the first time.(quoted from post at 17:43:39 05/04/22) I like to describe the two terminals on an ammeter as SUPPLY and LOAD. If one is marked BATTERY I would take that to be its SUPPLY with the other side as LOAD and its feeds voltage to loads like lights and ignition..
Try wiring the ammeters BATTERY to the battery, perhaps where the big battery cable attaches to the INPUT side of a starter switch or solenoid,,,,,,,, and other wires such as the Genny/Voltage Regulator (BAT on a Voltage Regulator) as well as the input to any light switches or ignition on the other LOAD side. If it reads backwards simply reverse the leads side to side.
Often theres ONLY ONE wire on the SUPPLY side IE the one that gets to battery with maybe TWO WIRES on the LOAD side, one to BAT terminal on a Voltage Regulator or Cutout relay and one to light and ignition switches.
Best guess on your ammeter BATT is the SUPPLY side and LIGHTS is the LOAD side. Wire BATT to battery and LIGHTS to light and/or ignition switches PLUS the output of the charging system (typical BAT on the VR) wires there also
John T
hat book/manual did that diagram come from?(quoted from post at 18:42:49 05/04/22) Follow the wiring diagram. Battery voltage is picked up at the supply side of starting solenoid, goes to the ammeter, then comes out the other side of the ammeter and goes to the terminal block for further distribution. If you get the wires backwards on the ammeter it will simply read backwards, switch the wires around.
<img SRC=https://i.postimg.cc/2S9pkTtL/Ford6-V-Wiring.jpg>
