AMP power port
bubbaobait
Trying to hook up an amp power connector whats the power , switch power and ground they are numbered 1,2,3 thank you in advance
(quoted from post at 21:41:45 05/11/19) Trying to hook up an amp power connector whats the power , switch power and ground they are numbered 1,2,3 thank you in advance
"amp power connector"
Our gracious hosts don't charge by the word, so feel free to add a little more detail as to what, exactly, we are playing with here!
(Or perhaps your post makes sense to everyone but me???)
We need at least a part number, picture, or description. I just put a remote on my jeep that allows
50 amp connection through a plug in connector. What vehicle/tractor purpose. Jim
If it is the 3-pin AMP connector used in
tractor cabs and so forth, #1 is keyed 12V
power, #2 is constant hot 12V, and the
sideways #3 terminal is Ground.
AMP power port for tractor, #3 ground, #1 12 volt switched, #2 12 volt all the time.... make sure it is fused, that should be right
