I just bought a 4star from out of a weed patch.I have it running and it has a slight tap or knock from the amplitorc area.If you put it into low,the noise goes away.The tractor slows down very slightly when you put it into low.I loaded the driveline by applying the brakes and the torc does not slip.It has good distinct snap when going from high to low or low to high.I removed the cover from the adjusting hole and looked in while moving the lever.The entire clutch pack and carrier is moving forward and backward about 1/4 of inch.I have the manual but I was wondering if anyone has seen something like this.I may not fix it and just part the tractor if it this is an expensive repair.Thanks,Moline
