AMT 600 wont start
Goat Boy
Im not sure why. Ive been driving this thing around for a couple weeks. I got the fuel filter replaced, put gas cleaner into the tank, because I noticed it was starting to sputter when Id give it gas. Since then its been really hard to start or it wont start at all. It seems like I have to crank a bunch. Typically I could start it by pushing down on the throttle with the choke all the way out then it would start. Now when I try the same technique it just doesnt want to start. The ignition seems to be working but the engine just doesnt want to get going.
Have you checked gas flow to the carb? Have you drained the carb to see if it has water or anything in the bowl? Have you checked the sparkplug? Have you checked to see if the plug is firing?
Did you put full bottle of gas cleaner in tank? I think full bottle is for 20 gallon tank. Empty gas tank and put in fresh gas. May take awhile to get fresh gas in entire system.
Ok. I have seen that the pump is spitting gas through to the carb.
Need to empty the carb to check for water. Need to check the
spark but the spark plug was just replaced.
